TwinTurbo.NET: Nissan 300ZX forum - Yeah it is tough to pick up, but it is fairly loud
Polishzx
on February 24, 2020 at 10:27 PM
hard to tell in video, but sounds top end to me
posted by Stanky (BC)
on February 24, 2020 at 08:35 PM
Doesn't come through very well until near the very end of the video. The only issue is that the motor is really running rough (like its down a cylinder). If something non engine-removey was the cause, I would be thrilled.
Got project running, but it has low compression. Need advice
Polishzx
18:34:36 02/24/20
Stanky (BC)
20:35:32 02/24/20
Yeah it is tough to pick up, but it is fairly loud -
Polishzx
22:27:05 02/24/20
How long was it sitting for? Sounds like lifters to me
itsa300zx
21:16:01 02/24/20
Not for too long, bit over a year.
Polishzx
22:28:29 02/24/20
My opinion is its top end clatter
Cjw3
21:22:09 02/24/20
Yeah, I wasn't sure what it could be
Polishzx
22:38:27 02/24/20
You probably have a slightly bent rod from hydrolock.
01:26:49 02/25/20
Would the compression go back up after putting oil in cyl?
ZXoltan
11:53:27 02/25/20
Sub 100psi is typically when you really feel a miss. (n/m)
13:38:17 02/25/20
I can try again with a smaller amount of oil
Polishzx
14:01:56 02/25/20
I'll definitely try it, thanks for feedback
Polishzx
14:01:21 02/25/20
Agree. Does sound like bent rod clap. See video in comments
volcomstone550
05:53:04 02/26/20
Based on your diagnostic work (well thought out and
SirpriZ
14:25:23 02/25/20
If its a bent rod you can fix it relatively easy.
volcomstone550
05:59:54 02/26/20
